R
I am using a yokogawa flange type DP Transmitter for measuring scalding juice tank level in sugar industry.
I Observed large zero shift (about 2000mmwc) at atmospheric pressure after 30 days usage of the transmitter. I tried to zero trim it with HART Communicator, but it is not accepting that much large correction. SO i replaced it with a new transmitter but the same problem came after 20 days of usage.
The diaphragm is found in good condition. the process fluid is scalding juice; it contains some suspended begasse particles.
I am not able to find a solution to this problem. Please help me!!
