G
We have experienced collector ring standstill, or ghost or footprint, marks on our GE 7H2 collector rings. It was noticed on a regular inspection after the unit had been offline for sometime - on turning gear for one hour a day.
Since the discovery we have changed our brush rigging - holders including springs - and have continued to monitor with no appreciable progression of the marking. The unit has relatively, to the sister unit, higher vibration (seismic - collector) but does not enter the alarm range.
GE provided an engineering response which indicated the rings should be resurfaced to ultimately fix the problem and increase preventative inspection routine frequency. We have gone out for proposals to have the rings resurfaced and, as expected, it is a rather costly. That being said the ultimate conclusion could be ugly - e.g. ring fire. Keep in mind we have no empirical data, e.g. vibration at the ring face, to point to but we think the symptoms speak for themselves. We did take some shaft run out data and it is slightly (one thou) out of spec - the accuracy of the setup could be argued so I would not call it definitive.
We feel it will not get better but we may be able to control it with increased maintenance. The one concern if it continues the damage to the ring(s) surface gets past the point of being able to correct it through resurfacing, or skimming, we may be faced with ring replacement.
I would like to hear of any experiences with these issues, outcomes, solutions, etc.
