W
I'm using a Integra 1630 energy meter with Modbus communication. Currently, I'm using Modscan32 to check the data. Most of the time i will only receive a register value of 0x00 while occasionally good replies. I tried changing the scan rate from 5000ms to 100ms but it is still the same.
Is there any adjustment that i can do to make the meter to have good replies?
