Thursday, January 18, 2018
PLC for Burner management system
How a PLC can be more than a Burner management system..
I'm an C&I engineer and I work in oil and gas companies. I'm working for the upgrade of a duct burner in which we have an obsolete safety monitor (The Safety Monitor is a logic system monitor designed to maintain plant safety in the event of a primary logic system failure or malfunction).
As a solution I want to replace this safety monitor with a "safety PLC" based burner management system, and I need more information and if this PLC can be more than a Burner management system ..
Hima, Tricon, Honeywell, Yokogawa....
HIMA has and can configure some special BMS safety PLC's with also special BMS application software, depending on the specific needs.
By Charles Fialkowski on 6 March, 2014 - 5:07 pm
Have you checked out my BMS blog. It's primarily focused on using safety PLC's for BMS.
https://blogs.siemens.com/burnermanagementsystems/
