Serial RS485 communication with Beckhoff CX9020(Master) and Entes MPR-53CS NetWork analyser (Slave).
- Program in the PLC is OK (verified by Beckhoff support)
- SlaveID, data bits, parity, stop bits, baud-rate. Everything is set the same in both the master and slave.
Master is trying to communicate with slave but goes into Time Out because the slave is not responding.
The wiring and connections are done as said in the both manuals.
Does anyone have any idea what the problem might be? Because I'm really stuck with this...
Thanks and kind regards
Dries Van den Broeke
Student EnergyTechnology
KaHo Sint-Lieven
9000 Gent, Belgium
KaHo Sint-Lieven
9000 Gent, Belgium
