I wanted to know if anyone had experance a failure of an ABEX 425 servo valve where the actuator closing seems to be working fine, but the opening flow is limited, i.e. opening too slow even with excessive current.
I'm thinking possible cause could be the fail safe spring has broken and the pieces stopping the spool from going full stroke.
Again, mainly looking for know failures, but will still like to hear any thoughts related to servo valves
