We are having a GE frame 9E gas turbine, which is under major outage.
The shaft is removed and is back after the maintenance. In bearing No:1, we are using axial probes which connected to Bently 3500 system. The voltage setting mentioned in device summary is -10.5 volts. How to adjust the axial probe? Do we need to move shaft with help of mechanical, while adjusting the probe?
The mentioned -10.5 volts is referred to which position?
Kindly advice.
Kindly advice.
