we have a lube oil filtration system for our GE Frame 9FA machines. The lube oil filter is having continuous vent for removing air. But the vent is working only when we are opening the 1/2" Filter drain valve. pl suggest the cause.
the lube oil pump pressure is 110 psi at a flow of 1050 GPM. the lube oil pumps are of buffalo make and the filter unit is Parker make.
[email protected]
[email protected]
