T
When you put the Alarm display control window in your application in InTouch, and choose which tags you want to show as "alarms." example; if you want to regulate the level in a tank, you want an alarm condition if the level is below 10%. Then the alarm would pop up in the Alarm display control and you could Acknowledge it. but when the alarm is off (higher than 10%), then the alarm (tag) would not be displayed in the Alarm display control.. So my question is: How do u choose to let the alarm stay in the display window when it's still off, so you have time to acknowledge it and do your things? It just disappears when the alarm condition is off, kind of annoying.
