P
Within the last 3 months I had in our company a strange behavior of the gas line. There is a main input turbine flowmeter that belong to the supplier and another 5 flowmeter inside our factory that belong to us.
Until a few months ago the main flowmeter reading was very close to the sum of the other 5.
Within the last months the difference increase something like 40%, 55% and 90% in the last month. We did a lot of verifications and also many checks in which we let only one line open in our factory that showed the same difference between the main flowmeter and our flowmeter.
(one detail that you may thing about: there is no error caused by the pressure, I used it for flow calculation in our test - also there are flow compensation devices on every sensor)
In the next day after the main flowmeter sensor was changed by our supplier, the reading comes true: the main flowmeter equal the sum of our 5 flowmeters, ... and the same in the last 2 weeks.
The flowmeter was sent to laboratory for testing and the result was that it is good, the error is within the 1% limits. I was there and I don't have any suspicion. One detail that may count: a lot of dust in the flowmeter that was cleaned before testing.
The only thing I could thing now is that maybe there was something wrong with the mechanical transmission between the turbine and the total flow indicator.
I kindly ask you for any clue or any of your similar experience that I may use for further investigations.
Best regards,
Petre P.
Best regards,
Petre P.
