G
Due to the malfunction of trip oil pressure switch the steam turbine got tripped. The trip oil is used to overcome the spring action of emergency stop valve (ESV) by which the steam goes inside the turbine. Process people are saying to remove the tripping of turbine from trip pressure low. They are saying that due to the less trip oil the ESV will close and it itself will stop the turbine? Pl suggest should I remove the tripping from Trip oil?
