V
Emerson mass flow meter connected to Rockwell PLC over MODBUS RTU in read write functionality.
Now we need to share the same data using the same RS485 port for monitoring in Honeywell HPM using SI interface.
Is it possible to use splitter or a bridge to share the same port?
What will happen if both masters ask for data at same time? Will the data gets affected in concurrent operation? Only read function is expected in Honeywell master.
