N
Generators with the same voltage level & same frequency and with the same rating, but with the different Speed (RPM) can be runned in parallel with the Synchro panel.
<b>Moderator's note:</b> I think the poster is asking "Can generators with the same voltage level & same frequency and with the same rating, but with the different Speed (RPM) be run in parallel with the Synchro panel?"
