We want to connect 9 AB PLCs over Ethernet/IP to a Ethernet Switch and from switch we want it to convert to DF1 and then connect to Honeywell serial FTA and Serial Interface card. What device needs to be used for ethernet/IP to DF1 conversion? Normally PLCs are connected to DF1 port and Control room PCs are connected to Ethernet. But here PLCs are on ETHERNET and control room PCs is o DF1 serial communication.
Pls.advise.
Chetan R J
Pls.advise.
Chetan R J
