how can sliding FSR logic operate on GTCs or GTGs when we change the composition of feed gas in case of lean or rich gas? normally it should works during the start-up and operation as well, but isn't like this for our case. this logic work only during the start-up, and as we saw when the gas composition had change (with lean gas) the behavour of gas turbine become slower. and it kept stable at 85% of HP shaft speed (and the SP is 100%).
the question is the FSR logic should probably gives more opening to the gas valve?
waiting for comments and help
thanks
thanks
