Hello
We have a stepping motor on turbine governor to increase or decrease speed. There is no diagram or name plate. The motor have 4 leads where 2 are joint together seems to be common say black and other two are separately coming out say red and yellow. we connected 220VAC neutral to common black and line to one by one red and yellow for forward and reverse direction movement. The problem is if neutral is with common black once line connect to red wire, motor move forward. but if switch off and again ON with same connection, the motor move in reverse direction sometime, with same connection move forward and some time reverse. Kindly advice if somebody have experience.
Shaheed ul islam
DI Khan
Pakistan
Shaheed ul islam
DI Khan
Pakistan
