The one that you apply and install properly. Most of the failures I've seen were due to misapplication or improper installation. For example, using relay outputs to flash lights is quite common. You will never know how reliable the PLC is because the relay will wear out.
Switching inductive loads with relay outputs with no arc suppression is another favorite way to reduce PLC life. Ignoring current ratings, etc. Switching inductive loads with transistor outputs with no flyback diode can produce instant failure. Wrong type of contacts for the load, excessive heat or shock. It's really hard to speculate on reliability as hard failures of the electronics are pretty rare. And the manufacturer doesn't publish much for data.
cww
cww
