We have a Hitachi H-25 gas turbine (similar to GE Frame-V machine). There are 03 Cpd transmitters but one sensing line from compressor. this tubing has developed a crack and normal cpd pressure at around 21-22 MW has dropped from 1.1-1.2 MPa to 0.89. We did some temporary fix on tubing by rubber and clamp but leakage is still there. cpd around 0.95MPa as a result of repairs.
My questions:
Can i replace this tubing online with cpd sensing tubing replacement using isolation valve at tubing outlet from compressor? Will the turbine change control mode to temp control ? Any other impact on turbine operation ? I cannot force the analog cpd values and median in logic ( only toggle access)..... Using forcing on digital signals can i prevent mode change ?
My questions:
