In our Generator there is a protection called V/Hz. What is it and why we use it? pl explain
S Thread Starter Santanu Jul 6, 2013 #1 In our Generator there is a protection called V/Hz. What is it and why we use it? pl explain
P Purrdie Jul 7, 2013 #2 > In our Generator there is a protection called V/Hz. What is it and why we use it? pl explain Try this link. Hope this helps. http://www.wisc-online.com/Objects/ViewObject.aspx?ID=ACE8304
H hfzaal Jul 7, 2013 #3 Hello Dear, Volt/Hz protection is also called over fluxing. which meant to exceed excitation over requirement at that speed. Have you noticed that Field breaker is only applied at speed > 90% of rated speed, just to avoid operation of Volt/Hz. This over fluxing may cause heating core.
