in thermal power House Condensing steam Turbine use Condenser/ejector for Vacuum creation at exhaust, and dump heat in condenser and again condensate water of 46 deg C heat up for feed water of boiler through LP & HP Heaters (waste of extraction steam).
my question is ....
1. why not use heat exchanger between Turbine Exhaust and Seconder to warm up feed water up?
are this method save a quantity of energy and what are disadvantage?
my question is ....
