I’m working as a project engineer. in our project we are having two differential expansion measurement. We are using Bently nevada 3300 XL 25 mm Transducer. For HP Differential expansion we are using direct differential expansion probe, and for LP Differential expansion We are using Complementary differential input method. my question is what is the difference between this two methods and Complementary differential expansion measuring principle?
And one more doubt, while doing rack configuration in Bently Nevada for differential expansion and axial displacement, there is option away from the probe/towards the probe. kindly clear which option i have to select?
