Hello Experts;
Good day. I need the P & ID of performance to clarify the installation of 96cs-1 transmitter on air inlet system.
Actually i am stuck between some air inlet system theory of the axial compressor. For example:
if the ambient pressure (Barometric pressure) is 14.5 PSIA, air inlet filter differential pressure is 2 " H2O and differential pressure inlet is 1.3" H20 then what is the P1?
There are also three points to measure the static pressure of the bell mouth inlet the readings usually round about 75 to 80" H2O what it means the static pressure at the bell mouth?
