P
Kindly clarify which product is actually required for given below application.
Early response will be highly appreciated.
Input air pressure .60 psig (fix) will transmitted to output port in normally open (NO) conditions. On trigger signal through solenoid valve the output port will close and cylinder pressure will release by exhaust port for valve opening. (Air pressure is reqd for additional thrust for not passing the liquid from on-off valve)
