N
My 800xA system used 2 PM864A Controller Redundant, last time some errors happen on system cause it can not run in redundant mode.
800xA redundant fail after 2 or 3 hours reset fault with the controller log errors:
W 2013-08-19 09:02:44.769 Unit= _SWTargets CNVController 4002 PualTest Error 00000003
E 2013-08-19 09:02:44.768 Unit= _SWTargets CNVController 4023 B:Bkp RCUMessHalt in Standby
E 2013-08-19 09:02:44.769 Unit= _SWTargets CNVController 4024 B: Backup CPU halted
E 2013-08-19 09:03:32.964: CLON: Primary ClonTaskRoutine() - Failed to send msg: 69643
E 2013-08-19 09:03:32.969: CLON: Primary ClonTaskRoutine() - Failed to send msg: 69643
E 2013-08-19 09:03:32.975: CLON: Primary ClonTaskRoutine() - Failed to send msg: 69643
E 2013-08-19 09:03:32.980: CLON: Primary ClonTaskRoutine() - Failed to send msg: 69643
E 2013-08-19 09:03:32.985: CLON: Primary ClonTaskRoutine() - Failed to send msg: 69643
W 2013-08-19 09:03:32.985 CLON: Cloning failed with error: 0x0001c005
E 2013-08-19 09:03:33.781: 4008 P:RCUMessHalt Lower CPU
E 2013-08-19 09:03:33.777 Unit= _SWTargets CNVController 4004 P:CloningError in Synch
E 2013-08-19 09:03:33.779 Unit= _SWTargets CNVController 4008 P:RCUMessHalt Lower CPU
The errors appear in two or three hours interval after a reset on controller. Although I already try replaced one new CPU, replaced RCU link cable but the errors still happen. Someone can see the problem I show me the way to do with this?
Thanks.
Thanks.
