N
Dear sir,
We are having Frame-V (MARK-V control system) supplied by M/s Thommossen.
Presently the machine running at 18.5 MW. At this load the speed of the machine is varying between 5100 - 5115 rpm. Few months before the variation used to be 5 rpm. Slowly the same getting increased to 15 rpm.
We have observed the following variations regard to FSR / SRV / GCV & Hydraulic Oil Pressures.
______ FSR variation is from 51.52 - 54.77,
______ SRV variation is from 42.11-45.43 &
______ GCV from - 50.01 - 54.25.
______ 78.0 - 76.5 bar.
All the above variations are cyclically happening and SRV/GCV are hunting in field in the same frequency. Inter stage fuel gas pressure and GCV gas out let are also having fluctuations.
We have a doubt the whether Hydraulic pressure is the reason or any other points to be addressed. Is it possible to increase the Hydraulic pressure on line when machine is running? If so how to adjust?
You are requested to suggest us the probable reasons for the speed & other variations and remedial course of action to be taken to control the variations.
