T
A GE-TM2500 SAC is operating now. We had replaced HPT speed pic-up three times due to sensor failure. sensor’s wiring has been checked as well.
For more information below some details:
- Machine controlled by Woodward
- sensor supply voltage: 24 Vdc
- sensor type: Transducer motion pic-up, P/N: L44920p01 with 187Ohm impedance
Any suggestions to verify sensor fail reasons?
Through my search for solution I read in Woodward manual that some controllers has impedance less than 300 ohm, A 300 ohm resistance should be placed in series with the sensor. Should we do this action? Is that going to effect on the sensor precision?
Appreciate your feedback
