G
We have recently completed a turbine and generator overhaul that included a GE compressor upgrade. During start up the turbine vibration started to increase at 3600 rpm. Will the unit require a balance shot to lower the vibration? Where will the balance weight be installed? I have heard it is done in the #2 turbine bearing area.
