hi,
Can we do to change the signal trip of HRSG Boiler from the shut down gas turbine signal to speed's gas turbine reach to 2850 rpm?
As you know, if gas turbine shutdown signal is activated, the HRSG boiler trip signal also is activated. but I want to change it from the beginning gas turbine shutdown signal activated to: if gas turbine speed reach to 2850 rpm then HRSG boiler trip. because may be problem exit to shut down the turbine solved before the gas turbine's speed reach to 2850 rpm.
please help me,
THANK YOU
please help me,
THANK YOU
