If we are using a differential pressure transmitter with an orifice plate. The pipe on which the orifice is installed is having two valves, one at the upstream and one at the downstream of the orifice. In normal conditions, both valves are opened, liquid passes through the orifice, creates the differential pressure for the transmitter to read.
What will happen when suddenly both valves are closed and there is a possibility of trapped liquid between the two valves. Will this create a differential pressure across the orifice?
