I have 2 tanks of same product, while the other is being filled the other will stand still and once the filled one is full the product will be switched to the empty one and the full one will the transfer to the store tank once it has been analysed. The project is to ensure that this two are not contaminating the store tank. Let only the transferring transfer to the store tank.
There are valves installed but this tanks share the one pump, so mistake do happen where the tank that is being filled get to transfer to the store tank which then contaminate the store tank.
How can I use the level transmitter alarm to alert the control room that now the Filling tank is transferring. Hint: I don't want to use control valves as they are costly and the level transmitters are already installed so I want to use the already available resource.
Please Help.
[email protected]
Please Help.
[email protected]
