F
I am trying to send and receive modbus messages between Wago PLC and MATLAB. Wago PLC is the master and matlab will be the slave.
(I checked my PLC programm with a modbus slave simulator and it works)
I can read the modbus message in matlab but I can not send a modbus message to the PLC.This is what I write in Matlab.<pre>
obj=udp('192.168.1.2',502); % Ip address and port number of my plc and i will use UDP connection
set(obj, 'LocalPort', 502); % local port is 502
fopen(obj);
Message_Taken=fread(obj);% i read the modbus message
%it is sth like this and this data is in double format in matlab
84 %(Transaction ID)
63 %(Transaction ID)
0 %(Protocol ID)
0 %(Protocol ID)
0 %(Length)
13 %(Length)
0 %(Unit Identifier)
23 %(Function Code)
0 %(Reference number for Read)
0 %(number of words for read)
2 %(number of words for read)
0 %(reference number for write)
1 %(reference number for write)
0 %(word count for write)
1 %(word count for write)
2 %(byte count (2X word count for write))
0 %(register value1)
254 %(register value1)
Transaction_Id_1=uint16(Message_Taken(1,1));
Transaction_Id_2=uint16(Message_Taken(2,1));
Transaction_Id=uint16(Transaction_Id_1+Transaction_Id_2);%16b Transaction Identifier
Protocol_Id=uint16(0);% 0 for modbus
Lenghf =uint16(6);% number of following bytes
UnitID=uint16(0);
Function_Code = uint16(3);% I use Function code 3 in slave
UnitIDFunCod = uint16(UnitID + Function_Code); % Concatenation of UnitID & FunctionCode in one int16 word
ByteCount =uint16(2);% number of data bytes
DATA=int16(29); % data that needs to be sent
Message_Sent= [Transaction_Id;Protocol_Id;Lenghf;UnitIDFunCod;ByteCount;DATA]
fwrite(obj,Message_Sent,'uint16');
fclose(obj);
delete(obj);</pre>
It gives no errors but I don't see the sent data in my PLC. I am quite new to modbus and if you figure out my mistake please contact me
[email protected]
fopen(obj);
0 %(Protocol ID)
0 %(Protocol ID)
0 %(Length)
13 %(Length)
23 %(Function Code)
UnitID=uint16(0);
fclose(obj);
delete(obj);</pre>
[email protected]
