In GE 9FA gas turbine hydraulic pump will switch on to lift mode while shutdown around 1350 RPM and off during startup around 450 RPM. Any one have idea about the reason of that big difference?
K | Turbine compartment monitoring for 9FA machine | General Communications Chat | 2 | |
M | Swirl effect in gas turbine GE frame 9FA | Power Generation | 2 | |
H | 9FA water injection | Power Generation | 3 | |
H | Gas turbine 9FA | Power Generation | 0 | |
M | Low lift Oil Pressure in 9FA Gas Turbine | Power Generation | 4 |
