9FA gas turbine seal oil system supply from lube oil pump. if lube oil system fail or stopped auxiliary AC seal oil pump will cut in. if it fail DC seal oil pump will start, but it's hardwired interlocked with AC auxiliary pump. that mean if DC started immediately AC will stop.
why we cannot run both pumps for short time as smooth transfer?
