K
I want to know in a high bypass turbofan engine like GE or RR how LP turbine drive big fan in head of engine? as know LP turbine has separate shaft from HP turbine, so how 2 shaft connect to each other? do LP shaft mounted within HP shaft OR both shaft installed in side and close to each other?
for a 3 shaft engine how is arrangement of shafts?
are 3 shaft parallel and closed to each other?
