my head is 45ft i.e, 14m
length of pipe is 22m
diameter of pipe is 2"
nozzel dia is 1/2"
I am using a chain drive to increase the rpm of alternator from turbine shaft, nearly 4 times.
can any one say how much electricity can be produced? i want to send the water collected at bottom to the overhead tank with the help of pump.
is it possible to use the same current generated for the pump to recycle the water.
email: [email protected]
nozzel dia is 1/2"
