OT CALCULATION
jamal
Hi every one
I am working as i&c engineer on Siemens gas turbine V94.2. I want to understand how can I calculate the OTC setpoint for making it as base load temperature set point after the maintenance major overhauls are finished?
H
Hussein Al Nawasrah
Hi Jamal,
The OTC calculation is equal to (Correction factor + Exhaust Temperature), both of these variables have a different formula depend on speed, synchronization and blow-off situation.
You can find all the information you need by going back to the function diagram on your SPPA-T3000 and you can follow the formulas from there.
