we have a problem (pipe vibration/Hammering) for steam line of HP bypass system. the temperature problems are located 30 Meter after the spray water control valve.
please, i need to know the the standard location (distance) of temperature measurement (TC) after the spray water control valve of HP Bypass.
parameters are: 50" steam pipe, 1.6 bar, 150 Deg C
ISA - ANSI or any other standard information is required.
