E
Hello all.
Firstly, apologies if I've not followed the correct posting etiquette by creating this thread.
I'll explain my setup. I need to communicate with a device (turbine) which follows Modbus RTU protocol. I need to extract one piece of data from the turbine and log it over time.
I am hoping to use a microcontroller (arduino etc.) to communicate via RS232 serial with the turbine to extract the data I want.
First of all, my understanding of Modbus is very new and likely very limited. As far as I can see, I am required to send my request to the turbine from the microcontroller over serial in 8N2 format (6 data bytes + 2 CRC16 bytes) and it should reply with the corresponding data.
I wrote code onto my microcontroller that performs said operation but when I've connected it to the turbine no serial communication eventuates.
I suppose my question is, have a underestimated the complexity of Modbus protocol and does anyone here have an idea where my knowledge of it is lacking?
