Dear ALL,
i am a C&I engineer with renowned poer group and our DCS is get failure repeatedly on 3-4 month which causing a huge almost 4 crore loss to my company. when i checked found
Ground - Neutral = 104 vac
Phase - Neutral = 224 vac
Phase - Ground = 124 vac
When i asked to my electrical personal about this they said the UPS supply used to be floating voltage (ie G-N=104). so kindly suggest me the ideal condition for this system as workstation motherboard and others are the frequently getting Damaged in my plant which causing a huge loss to my company.
<b>Moderator's Note:</b> Fixed as many misspelled words as I knew. Left the others alone.
