I have seen a configuration of a dead bus synchronization that once the Generator Breaker is closed. the Valve will have about 2 % constant kick added to the valve output. I understand that this kick shall be when synchronizing to a live bus so the generator can some power once the breaker closed. but is this configuration on having a valve kicked when sync to dead bus is correct?
Thanks in advance for your reply
