F
We having a frame 5 gas turbine and just complete the 48,000 Hrs services and would like to perform a performance load test. the unit has rich up to 14.1 MW and normally the unit is rated for 23 MW. we have faced an alarm which is Excitation Limit Operating (70 EX-LIM), we have other unit and was tested with the same and do not faced with Excitation Limit Operating (70 EX-LIM). the unit was loaded up to 16 MW with out any problems.
We have check the Excitation panel and found no much found.
Therefore kindly advice us back with your technical support for this matter.
Waiting for your feed back by return.
Fathi Hadloul
Power Plant Coordinator
Fathi Hadloul
