I have an assingment to measure 3 rooms' temperature, which are SIH, MCC and Battery Room. I use Thermocouple type J which range is from 0 - 780 celcius degree.
My mentor said I have to shorten the range of the sensor, in order to have a better accuracy in reading the value of sensor's output (the range is from 4-20 mA).
I'm thinking to change the thermocouple's range from 10 - 60 Celsius degree. I've read literatures about calibrating the sensor, but I'm still not sure about the process and how it will affect the sensor itself.
Please help, and thanks in advance
With Regards,
Castolina
With Regards,
Castolina
