Dear Fellows;
I have face high vibration problem on a two shaft gas turbine. It require some trim/Field balancing.
I have adopt the 4 run method and calculate the values by draw a circles manually and then find the weight and angle. I want to know is there any software for field balancing which gives me also some solutions after vector subtraction like when i put the angles and weight?
