I
Hello
I have a question. Inlet Guide vanes are used to regulate the air flow into the gas turbine, and introduce a swirl to control the mach number. But what exactly is the function of EGVs?
1) Its function is to eliminate the swirl in the air at the exit of compressor? or is there any other special function as well.
2) If it eliminates the swirl that means in case of high spread, any thermocouple showing high temperature (above alarm value) means that we have to check the particular combustion chamber directly behind that particular thermocouple showing high temp alarm. The concept of swirl will finish?
3) Currently I have a software which shows the number of chambers to be checked in case of high spread. It asks the frame of GT, the load at which the spread exists. After we put the data it gives the location of chambers against the Thermocouples by incorporating the swirl effect. Swirl is Maximum at zero load while minimum at Full load, why is it so?
4) In this case where we have EGVs installed, do we have to take into account the swirl effect? I mean should I trust that software.
Izhar
Izhar
