BM85 connections to a 984 265 Via MODBUS
I
ioudas
Hi All,
I have a bm85 I am trying to connect to a quantum 984-265 via a bm85-000 base model.
<b>Moderator's Note:</b>Please scroll down for table. Space left so you can see the entire table.
I have ports 1-4 configured as<pre>
P>PORT NUMBER# 1 2 3 4 [1, 2, 3, 4]
<T>Port Type master master master master [m, s, n, x]
<N>Slave Dev Addr - - - - [1 - 247]
<B>Baud Rate 9600 9600 9600 9600 [300 - 19200]
<S>Stop Bits 1 1 1 1 [1, 2]
<R>Parity even even even even [n, o, e]
<M>Mode rtu rtu rtu rtu [a, r]
<Y>Priority 1 2 3 4 [1 - 4]
<L>Link Timeout - - - - [1 - 3000]
<F>Modem Booster - - - - [y, n]
V2 Entry for p1
<E1 > [001]= 020 000 000 000 000
v2 entry for p2
None configured
v2 for entry for p3
<E1 > [002]= 020 000 000 000 000
v2 for entry for p4
<E1 > [001]= 020 000 000 000 000 </pre>
I am using fastrax plc software to connect.
I am using a 990NAA26320 cable with a manual pin out with the 1/4/6 not connected. I have tried with 1/4/6 connected without luck as well.
According to my cursory glance at the x10 and x1 ports there is a plc on id 20 and high speed controller on id 21
All ports do not provide connectivity currently.
So what am I missing? These all connect back via the 990 cable to a prolific db9 to usb convert then into a laptop. However If i set routes or do not set routes I am still unable to talk. Am i using the wrong cable or have i setup routes wrong?
