I'm noticing that the 0-10v output from my sensor is not as stable as I'd expect or like. the sensor is a distance measuring device and although I'm expecting a slight variation, what I'm seeing is unworkable in my current application.
When I measure the output with a voltmeter, I see as expected and see the expected variance when I simulate distance measurement change but when connected to my logging software instead of seeing a stable volt reading, I see occasional peaks and dips (this might be at the same frequency), thinking possibly a by product of the AC-DC conversion?
Anyway, I'm using a decent 24v DC power supply and the sensor without mentioning brands is of good quality, as is the logging equipment and software so...
Is this variation the kind of things I would expect to see and if so, should I be considering a smoothing capacitor or something?
All help appreciated...
