T
I am trying to find out how fast the generator terminal voltage would collapse if we removed the field current from the generator. What is the driving factor?
Also, if we were to switch in a shorting resistor across the field input of the generator would that increase the rate at which the voltage collapsed?
Thank you.
Thank you.
