R
Dear,
Rock is getting on loaded in Y01 conveyor. Y11 conveyor gets the feed from Y01. Y11 is running with two motors in master slave mode and load sharing mode. Motors are being driven by AB VFD. PLC is being used for intercommunication between VFDs. Set point for master motor is given from C/R. System runs normal during normal load period. When sudden heavy load comes on conveyor then slave motor gets over-speed and system trips.
