E
hallo guys, I use a gas engine to drive a synchronous generator. But I have a problem about how to avoid the 15% overspeed by changing the last from 100% to 0%.
When the load from 100% to 0% changes, at the same time I also completely close the throttle, because of the large mass of the generator rotor, it means there is great inertia, so the speed rapid increased and reached 14.5% overspeed. It is already close to the 15% overspeed protection.
If I use the speed governor instead, the throttle cannot be immediately completely closed by loss of the full load. More than 15% overspeed will occur in such a situation. Could anyone have some ideas or solutions for that?
