Hi.
First I want to thank control.com for a lot of practical informations about GE gas turbines.
I am a PHD student who is developing a mathematical model of Gas Turbine PG 9171e. I have some questions about the compressor in this machine.
1. Can someone give me information about design compressor efficiency and design compressor capacity? I need this values for scaling an existing map of compressor.
2. What is the maximum flow through inlet bleed heat valve (I mean percentage values)- Combustion Chamber is DLN-I
3. And the last question – I need a value of air mass flow rate in case when the Inlet Guide Vanes are full closed (ankle 57 DGA) and full open (84 DGA ).
Thank a lot for answers!
Best regards.
Marcin
Best regards.
Marcin
